TwinTurbo.NET: Nissan 300ZX forum - Well.. it sounds to me like a master/slave going out.
Draker (Eugene, OR)
on October 12, 2011 at 10:24 AM
I think my clutch is gone... want to clarify before I dig in
posted by Red Hawk (CO)
on October 12, 2011 at 12:31 AM
A way to test the clutch is to start it. Put it in 5th gear and dump the clutch. If it dies right away, your clutch probably isn't slipping. If it doesn't die right away, the clutch is slipping.
Red Hawk (CO)
00:31:13 10/12/11
Well.. it sounds to me like a master/slave going out. -
Draker (Eugene, OR)
10:24:00 10/12/11
I'll give it a shot, Last time I tried, it wouldn't go into
Red Hawk (CO)
11:26:28 10/12/11
First before you do anything get someone to press the clutch
Bo (Houston)
11:29:01 10/12/11
Sounds like the same symptoms as mine. Pulled my tranny and
jmt-z
13:42:58 10/12/11
You were right. Clutch spring gone (n/m)
Red Hawk (CO)
19:00:55 10/15/11
Sounds like a broken pivot ball or fork.
Joe@ZSpeedperformance
19:24:27 10/12/11
Really? well I got in the car and could shift with car off
Red Hawk (CO)
20:30:49 10/12/11
It doesn't matter if you have the clutch pressed in when
Bo (Houston)
20:48:29 10/12/11
Oh the rubber boot that is on the slave? or right next to
Red Hawk (CO)
21:07:02 10/12/11
Solved. Clutch is broken. (n/m)
Red Hawk (CO)
19:02:09 10/15/11
What exactly happened to it? (n/m)
Bo (Houston)
03:23:16 10/16/11
Back spring retaining plate on the clutch that faces
Red Hawk (CO)
10:07:25 10/16/11
Same thing happened on my 3nd clutch - 94TT.
Zirvana
16:42:57 10/19/11
